STEVAL-PROTEUS1 to monitor temp and vibration on a spindle
Cornwlp
Associate
I am trying to use a proteus1 to monitor temp and vibration on a spindle and i just cant seem to find the best way to do this. I would  like to use a cloud so I can monitor it off site and get a notification if the temp rises above a threshold. what would you recommend. I have tried the azur cloud i can get the device to connect but then in the classic app i can not get it to send any information. I have tried almost all firmware versions and just cant seem to crack this. Anything will help.
Thank you,
2 REPLIES 2
mƎALLEm
Your question is not clear. In which context? motor control application or what?
Please read How to write your question to maximize your chances to find a solution
PS: you've posted your request in a wrong forum.
I just want to be able to use the device mounted to a spindle and be able to monitor temp and vibration. The app is not great for doing this off site what are some options. Or ideas I have tried the app and it isn’t great for continuous monitoring or off site using a form of cloud. The app doesn’t work with IoT or at-least not efficiently.
