2014-03-14 8:11 AM
How can I get answers from you? Next try. This is a typical sequence with FS=00 and DR=11 and the chip lying on the table. How do you review this? Your spec says TyOff +-1g, and So=0.049. Where does this noise came from ( +3g on Z-Axis) ACCELERATION ff70 ffd0 2c0 -0.439453 -0.146484 2.148438 ACCELERATION fec0 fff0 190 -0.976563 -0.048828 1.220703 ACCELERATION ff20 090 490 -0.683594 0.439453 3.564453 ACCELERATION fff0 020 320 -0.048828 0.097656 2.441406 ACCELERATION ffc0 0a0 20 -0.195313 0.488281 1.562500 ACCELERATION ffe0 040 260 -0.097656 0.195313 1.855469 ACCELERATION ff60 ffb0 250 -0.488281 -0.244141 1.806641 ACCELERATION fff0 030 480 -0.048828 0.146484 3.515625 ACCELERATION ffc0 fff0 1c0 -0.195313 -0.048828 1.367188 ACCELERATION ff60 fff0 2b0 -0.488281 -0.048828 2.099609 I've now created a document with some graphics. Please answer.2014-03-15 10:47 AM
I've got similar values with a H3LIS331DL accelerommeter on a +-400g range working at 3.3 volts, datasheet explicitely says they are factory calibrated at 2.5 volts, I don't know if that is important though.
I had to calibrate it myself and implement IIR filtering to get static and dinamic acceleration, that way it suits my needs and calculations are more accurate, but I don't know if those values are expected or there is a problem with my pcb.We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
