2025-11-27 5:27 AM
Greetings,
we are working on to evaluate the data given in lsm6dsv datasheet ,we want to verify the sensitivity and rest of the parameters,could you please provide us the test setup/suitable test rig details with which we can test the sensor...
Thank you
2025-11-27 7:47 AM
Hi @shalinich67 ,
For the gyroscope, a rate table is commonly used. This device rotates the sensor at precisely controlled angular velocities, allowing you to compare the sensor output to known rotation rates.
You can use a rate table also for the accelerometer, otherwise a tilt platform with accurately known angles is typically used to test sensitivity in static conditions.
2025-11-30 8:26 PM
Hi, @Federica Bossi
Thank you for the information.
However, rate tables and precision tilt platforms are quite expensive and beyond our budget for this evaluation. Could you please suggest a simpler or low-cost test setup that would still allow us to reasonably verify the gyroscope and accelerometer sensitivity and basic performance parameters of the LSM6DSV?
Any guidance on practical, budget-friendly test methods would be greatly appreciated.
Thank you.
