2025-12-09 4:41 AM
We are evaluating the LSM6DSR's noise floor for a specific use case. Based from the datasheet the noise is 60ug/sqrt(hz).
So calculating the RMS noise at 208Hz should result to 0.00062 m/s^2 right? However, we are getting measured RMS values around 0.002 to 0.004 m/s^2.
Here are some configurations set
FS: +-2G
ODR: 208Hz
Data acquired using FIFO reading every 500 samples
No onboard filtering enabled.
I have attached a sample dataset for your analysis as well.
2025-12-11 6:14 AM
Hi @adrianT ,
60×10−6×9.80665=0.0005884m/s2/√Hz
Considering a BW of 104Hz (ODR/2) -> 0.0005884×√104=0.0005884×10.198=0.006m/s2
Your calculation of 0.00062 m/s² seems to be off by a factor of 10, the correct RMS noise from datasheet noise density at 208 Hz ODR should be approximately 0.006 m/s².
Your measured RMS noise values of about 0.004 m/s² are acceptable.
2025-12-11 6:14 AM
Hi @adrianT ,
