2023-09-18 1:28 AM
We have following configuration in CTRL1:
ODR[3:0]: 1001b (High-Performance / Low-Power mode 1600/200 Hz)
MODE[1:0]: 01b(High-Performance Mode (14-bit resolution))
And the value in the "LP_MODE[1:0] " might be different depending on the state we came from.
The question here does the value in the "LP_MODE[1:0] " have any affect in this configuration when high performance is selected in MODE[1:0]?
2023-09-18 8:20 AM
Hi @MBoch.2 ,
If you select High performance Mode with the bits MODE [1:0] than leave the LP_MODE[1:0] at the default value so that the high performance configuration will not be affected.
If this helps you, please mark my answer as "Best Answer" by clicking on the "Accept as Solution" button, this can be helpful for Community users to find this solution faster :)
2023-09-18 8:20 AM
Hi @MBoch.2 ,
