2021-04-13 9:02 PM
2021-04-14 2:41 AM
Hi @MVran.1 ,
Are you using the B-L475E-IOT01A board, right?
If so, you can check the FP-AI-SENSING1 firmware function pack, that is designed also for the STM32L4 Discovery kit IoT node.
In particular, you can consider the Sensing1 application that you can find in the \Projects\B-L475E-IOT01A\Applications\SENSING1, that manages all the onboard sensors, included the humidity HTS221.
Let me please know if this can be helpful for your purpose.
-Eleon
