2020-05-13 4:02 AM
This actually makes sense because the ODR is 26,667 kHz which means that between two samples are 37.5 us this would make three 12.5 us ticks. 25 us wouldn't make much sense.
2020-05-15 2:53 AM
Hi Eleon,
Thank you for your reply!
I've read both datasheet and app note but I still think the value mentioned there is wrong. Here's how i come to this conclusion:
Setup:
IIS3DWB Eval Kit connected to 180 MHz Cortex M4 MCU via SPI (4 wires) @ 10 MHz, both Interrupts connected
ODR 26,667 kHz, Timestamp active, DRDY Interrupt to INT1
First test:
Count the INT1 DRDY Pulses during 1 second - Result 26667 Pulses per Second +/- some ticks due to timing issues and maybe some clock errors (but very close to 26667 = no problem)
Second test:
Read the 32 bit timestamp value after each DRDY Pulse, Calculate the difference between the timestamp values after two consecutive DRDY Pulses - Result: The difference in timestamp values between two DRDY Pulses @ 26667 Hz ODR is 3 ticks
This leads me to the conclusion that the timestamp tick resolution is 12.5 us because between two consecutive DRDY Pulses @ 26667 Hz there must be 37.5 us, so 37.5 us / 3 ticks = 12.5 us / tick
25 us wouldn't make much sense simply because there would be 1.5 ticks between two samples and the tick value is an integer. So your IC designer would probably choose an integer value for the tick count between two samples.
If your datasheet is correct I guess I have another chip revision...
Best regards,
Martin
2020-05-13 9:31 AM
Hi @MNoll.2 , I believe you are right, but let me please check internally.
I can say that formula reported on the datasheet p. 38 can be used to calculate an estimation of the actual timestamp resolution:
TS_Res = 1 / (40000 + (0.0015 * INTERNAL_FREQ_FINE * 40000))
// INTERNAL_FREQ_FINE is the difference in percentage of the effective ODR (and timestamp rate) with respect to the typical. Step: 0.15%. Register INTERNAL_FREQ_FINE (63h)and the 25us value comes from INTERNAL_FREQ_FINE = 1 LSB. Regards
2020-05-15 2:53 AM
Hi Eleon,
Setup:
First test:
Second test:
Best regards,
Martin
2020-05-15 6:51 AM
Ciao Martin, your argument is valid, especially if supported from empirical measures... let me please check internally and come back to you. Regards
2020-05-18 7:38 AM
Checked internally, there is the possibility we have to update IIS3DWB datasheet and app note on this topic. Thanks @MNoll.2 for the issue reporting. Regards
