LIS3DH Click Interrupt
Posted on March 25, 2014 at 22:50The data sheet makes no explicit mention of a way to force this interrupt to latch and clear when the CLICK_SRC register is read (like the INT1_CFG registers can).App note AN3308 states that this behavior can be achi...
jose by Associate
  • 995 Views
Inemo-M1 'LSM303DLHC_AccDataReady.c' problem
Posted on June 18, 2014 at 11:54Hi guys,I have jsut started using the Inemo_m1 discovery board.After Installing the software and doing some hello world projects (using KEIL IDE;debugged via ST-Link debugger), I decided to setup communication with th...
bouvett by Associate
  • 1977 Views
LIS3MDL reboot memory
Posted on July 09, 2014 at 13:00CTRL_REG2 contain REBOOT bit - ''Reboot memory content''. Which memory this bit reboots?A found only one memory - non-volatile memory trimming values ofsensitivity (So) and Zero-gauss level (TyOff). If I can reboot th...
glory_man by Associate II
  • 1051 Views
lsm303dlhc magnetometer issue
Posted on March 21, 2014 at 05:56hi, i got accelerometer values in correct way . but magnetometer values are not coming with accuracy. can any one suggest me. how to solve this issue. Regards srinivas
LSM303C
Posted on July 07, 2014 at 15:40Hi all,I am working with the LSM303C and with the EVALBoard ST8S003VLDISCO. When i want to access the Magnetometer data it is giving me some strange values.The Values of the High-Byte are staying constant always with ...
Forum for STEVAL-MKI121V1?
Posted on July 06, 2014 at 04:12Hello, I know this isn't the place for discussing anything other than the 062V2 but I am having trouble searching through the forums for info on the 121V1. I'm having trouble getting my computer to recognize my eval b...
c2399 by Associate
  • 801 Views
L3G4200
Posted on July 04, 2014 at 15:22Hello,I got good results reading gyro data but the temperature register is about 13(decimal), the datasheet mentions -1LSB/°C, so what is the offset?Room temp is 24°C, the other sensors located near the LSM are indi...
tarzan2 by Senior
  • 798 Views
Accelerometer Data Delay in LSM330DLC
Posted on July 03, 2014 at 05:08Hello!I'm using LSM330DLC to accept the accelerometer, I want to know the sampling and conversion time of a data, but this time cannot be found on the datasheet. If someone can help me ?Thanks
chenj047 by Associate
  • 844 Views
LSM9DS1 Active Date and Questions
Posted on July 03, 2014 at 01:56I am considering using an LSM9DS1 over a LSM9DS0 in a design I am working on. I have read both data sheets thoroughly and think I have a pretty fair understanding of each part. My questions are as follows.1. When is t...
lucas by Associate
  • 840 Views
