Resolved! What is the base address of the VL6180X registers?
Posted on April 25, 2018 at 21:56Looking at the data sheet for the VL6180X (p49-50), the registers are listed with their 'offset' address.Does this mean I have to add a base address to the offset addresses? If so, where is that found in the document...
gbarbour by Associate III
  • 1017 Views
Strange behaviour with LSM303DLHC
Posted on April 30, 2018 at 12:25I am seeing some curious behaviour with the LSM303DLHC sensor. I am using the magnetometer only, reading at 200Hz. My software responds to interrupts on the DRDY pin by reading six bytes starting from register OUT_X_...
Interrupt and FIFO settings in ISM330DLC
Posted on April 27, 2018 at 09:15Please tell me the details on Interrupt and FIFO settings in ISM330DLC. I need to store the Gyroscope and Accelerometer data into the FIFO . Please tell me what changes i need to do in kernel source code of ism330dlc...
shammi d by Associate II
  • 951 Views
Resolved! LIS2DH12 excessive current draw
Posted on April 16, 2018 at 12:37I am using LIS2DH12 on my custom designed board for a BLE application. I noticed that the PCB had a huge current draw than expected and on further digging found the accelerometer to be drawing the excessive current w...
How to upgrade firmware for STEVAL-MKI109V3?
Posted on April 23, 2018 at 21:33Hi, I downloaded the Unico 6.0.0.0 and selected the STEVAL-MKI179V1 for LIS2DW12 sensor. I am using the motherboard STEVAL-MKI109V3 and i getting the same error. How to solve firmware issue for this motherboard?I hav...
Configure interrupt for LIS2DH12
Posted on April 24, 2018 at 17:11I am trying to configure an interrupt on a LIS2DH12 in order to detect when the device is being hit.I tried just configuring one axes to generate the interrupt. But Interrupt is never being fired (Or it is fired cons...
P M by Associate III
  • 883 Views
MotionFX and rotation_9X
Posted on April 24, 2018 at 13:34Hello to allI'm trying to use MotionFX sensor fusion library in my application with STM32F4.It seems to me that the 9X mode works good enough. But I'm confused about my results during sensor rotation around 3 axis:1)...
How to add STEVAL-MKI179V1 into Unico device list
Posted on November 10, 2017 at 09:57when i use STMicro motherboard STEVAL-MKI109V3 to evaluate the MEMS sensor board STEVAL-MKI136V1 and STEVAL-MKI179V1, found some problems.1. I can not find the STEVAL-MKI179V1 in the device list of Unico.    How t...
_legacyfs_online_stmicro_images_0690X0000060MvQQAU.png _legacyfs_online_stmicro_images_0690X0000060MvfQAE.png
Cann't complie to eMotionV2_REL_5.0.0.zip(in en.stsw-mki109w.zip)?
Posted on April 24, 2018 at 10:31Hi..I use STEVAL-MKI109V2(Demo board) and MKI160V1(sensor).and i use IAR Embedded Workbench V7.20 Version..so when i open to project file,comming message like this..'Broken options were detected in the project file A...
sw lee by Associate II
  • 797 Views
