How to use PDM MEMS microphone on PB8 (MCLK) with STM32WBxx
I am using the MEMSMIC1 Microphones_Streaming example (https://www.st.com/en/embedded-software/x-cube-memsmic1.html) with the STM32WBxx chip. I am trying to change the clocking pin from PB13 to PB8 to use the example with custom hardware.I am trying ...
FFlet by Associate II
  • 1079 Views
Resolved! LSm303agr power-down
Hi guys,I'm using for first time LSm303agr sensor and I have a question about low-consumption of the sensor.Reading the Electrical characteristic I see that the sensor can achieve a low consumption of 2uA but I don't know what registers can do it.I u...
MM.10 by Associate II
  • 3026 Views
blog.st.com
We’ve just announced the launch of a new sensor unit called SensorTile.box. It is a flexible IoT Plug and Play module to jumpstart sensor-to-cloud IoT applications.Find out what you can do with the SensorTile.box by reading our blogpost at  https://b...
Resolved! Problem with L3G4200 Sensor using I2C
I have a problem interfacing with L3G4200 using I2C on STM32F469 Discovery. Here is my code to config the I2Cvoid I2CConfig(void){ I2CHandle1.Instance = I2Cx; I2CHandle1.Init.AddressingMode = I2C_ADDRESSINGMODE_7BIT; I2CHandle1.Init.ClockSpeed = ...
Resolved! Microphones streaming through I2S
Hi,I'm trying to implement the streaming of two MEMS microphones via I2S.Following some examples provided by ST, I was able to implement the acquisition of the two microphones: I obtain a 32 samples buffer PCM every 1 ms (left and right channel).Now ...
Fib by Associate II
  • 2066 Views
VL53L1X NON_BLOCKING measurement
Hey,I am using the vl53l1x on a raspberry pi with python (pimoroni library). However, to my knowledge and experience, by default the waiting method for measurement data is BLOCKING. So in Python the get_distance() function takes about as much time as...
VL53L1X test with a foggy area and distance impacted!
Posted on June 12, 2018 at 10:28Description:We use 4 -VL53L1X sensors in our product and we have a closed box (rectangular shape), in which we place a foggy stuff for a worst air condition to see object distance impact or not.Before the foggy stuff ...
leo su by Associate II
  • 2084 Views
