LSM6DSO or LSM6DSOX?
Hi everyone,is possible to determinate which module is mounted between LSM6DSO or LSM6DSOX reading some registers?Thanks and Best Regards,Leonardo M.
ontares by Associate
  • 1261 Views
Do these IIS2DLPC XYZ output values look correct?
Hello, I apologize in advance for my long post, and ignorance when it comes to interpreting this linear accelerometer data. The only one I have used in the past gave me euler angles, and I had no problem calculating tilt from them. I am trying to per...
IIS3DHHC. MSL3 preconditioning.
What exactly "MSL3 preconditioning" means?Does it mean the same as "baking"?This preconditioning corresponds with soldering, or all the time?How accuracy are affected by moisture?I understand that omitting the baking before soldering, will cause crac...
STSW-MKI109W firmware upgrade
I had an error // not supported by motherboard // when connect STEVAL-MKI197V1 to UNICO like the image error.png attached.I reinstalled STM32 drivers, reinstalled UNICO,... but could not solve the problem.Then I upgrade firmware by command line in U...
Tam Tran by Associate II
  • 1823 Views
