Resolved! Unit of minimum threshold in LIS2DS12
Hello ST community,In LIS2DS12 application note, section 5.9.1, it is mentioned that the minimum threshold can be set where 1 LSB = FS/64. I would like to confirm if the value in this register has the unit of g. Also, if +- 2g is the selected full sc...
AB.4 by Associate II
  • 1107 Views
Resolved! Having problems getting compression to work on the LSM6DSOX
Trying to enable compression. I only see tags 0x01 and 0x02, none of the compression tags.bellow is my reg inits.#define IMU_READ_BIT 0x80   #define EMB_FUNC_EN_B 0x05 #define FIFO_CTRL1 0x07 #define FIFO_CTRL2 0x08 #define FIF...
DFors.1 by Associate II
  • 3941 Views
Application example for step counter using LIS2DS12
Hello ST community,I would like to know if there are examples available for configuring LIS2DS12 for pedometer applications. I see that the Github examples (https://github.com/STMicroelectronics/STMems_Standard_C_drivers/tree/master/lis2ds12_STdC/exa...
  • 1434 Views
Does Sensortile.box support mesh ble networks?
Hi everyone, I am trying to develop a mesh network using many sensortile.box, is it possilbe to use STSW-BNRG-Mesh with Sensortile.box? If it is not possible how is there any SDK available for Mesh networks using Sensortile.Box?Thank you.
LMaga.2 by Associate
  • 1017 Views
SensorTile.box connection problem
Helloi am trying to program my sensortile.box in pro mode. I have everything I need to be able to upload binary files (JTAG adapter, ST-LinkV2) but I encounter this error. Can anyone help me?
GCele.1 by Associate II
  • 1108 Views
How to light a LED with PNUCLEO VL6180X
Hello I would like to have your help I use the vl6180X sensor for a proximity detection, on PNUCLEO, I want to know how to turn on an LED, I programmed the thresholds of my interruption and I would like to turn on an LED on the gpio1 the time of inte...
MSAMB.1 by Associate III
  • 1320 Views
Resolved! I am facing issue while programming STWINKT1 board using stm32cube ide
I am previously using STM32CubeIde version 1.3.0 and i am able to programme the STWINKT1 development board successfully. while i am debugging suddenly my laptop crashed and when i power on it again now i am getting error.So i uninstall version and do...
karan by Associate III
  • 1723 Views
