VL53L1 Ranging instability in strong ambient light
Hi,I'm trying to use multiple VL53L1X sensors to detect objects. I successfully interfaced them with a Raspberry Pi 4B, and tried to tune a bunch of parameters to get good detection.When the sensors point to an object, within the sensor range (0.4 - ...
THilt.1 by Associate II
  • 3984 Views
What are the necessary Configuration and Calculations for LSM9DS1?
Hi Team.We are using LSM9DS1 with MCU (S32K146) via I2C. We have tried enabling the acc and gyro with CTRL_REG1_G and CTRL_REG6_XL .We can able to read the Who am I register properly. But the data output registers of acc/gyro are giving different val...
LG.2 by Associate
  • 1734 Views
Resolved! LPS33HW Temperature absolute accuracy
Temperature absolute accuracy. This parameter was not found in the datasheet.Of the 15 sensors tested, the temperature ​difference was 5 degrees.What ​temperature absolute accuracy should be?
PSoko.1 by Associate II
  • 1761 Views
I tried to install the GUI en.STSW-IMG004 to run my EvalBoard with VL53L1x. But the insatllation end with Error Massage 1721.
Hello everybody,I tried to install the GUI en.STSW-IMG004 to run my EvalBoard with VL53L1x. But the insatllation end with Error Massage 1721 (see attached). I ried it also on a second Hardware with the same result. What did I make wrong? Regards Dani...
DPalm.1 by Associate
  • 1638 Views
