STEVAL-STWINKT1 Stuck in Bootloader mode after a new binary flash
Hi,I am trying to upload a new example binary on to the device. The binary is from here:https://my.st.com/content/my_st_com/en/products/embedded-software/mcu-mpu-embedded-software/stm32-embedded-software/stm32-ode-function-pack-sw/fp-sns-datalog1.lic...
DLim.16 by Associate II
  • 1316 Views
I have lsm6dso imu. I want to use two wake up interrupts at the same time. Thresholds and duration will be different. I cannot use it at the same time because I changed the register value while doing the settings.
I have lsm6dso imu. I want to use wake up interrupt for two different thresholds at the same time,for example I want to give wake up threshold 1g for interrupt 1,I want to give 500 mg for interrupt 2. And duration will be different.I change the value...
Iakgu.1 by Associate III
  • 2223 Views
I2C implementation between STM32 MCU and sensor using Low-Layer API
Hello,Could you share any examples of I2C communication implementation between STM32L011 MCU and temperature sensor using Low-Layer (LL) API? I am trying to read temperature values from temperature & humidity sensor HDC2080. I found a library for thi...
Indois by Associate II
  • 1584 Views
Resolved! X-CUBE-MEMES for LSM9DS1
Hi,I am trying to calibrate my IMU on a custom board using X-CUBE-MEMS package. However there is no support for the LSM9DS1 part. I've seen on the community that the alternative for the Accelerometer+Gyroscope is the LSM303AGR library. However, this ...
PMach.1 by Senior
  • 1744 Views
Resolved! How to reset the timer in LSM6DSO IMU FIFO
Why did you guys remove the feature of resetting the timer for LSM6DSO IMU? It was available in LSM6DS3 by setting AAh in TIMESTAMP2_REG (42h).How do we reset the timestamp value in FIFO (LSM6DSO chip)?
BDiva.1 by Associate II
  • 2083 Views
VL53L1X - Problems with Ultra Lite Driver (ULD) crosstalk functions "VL53L1X_SetXtalk()" and "VL53L1X_GetXtalk()". Wrong values.
HelloI have problems with Ultra Lite Driver (ULD) crosstalk functions "VL53L1X_SetXtalk()" and "VL53L1X_GetXtalk()". I'm not sure if I have made a mistake or if there is an error in the ULD. I will give an example to explain my problem. #############...
