Calibration using MotionAcc library
I am using the industrial IIS2DH accelerometer in our vibration analysis product. I am collected data using the data-ready interrupt. For improving data accuracy I want to perform some calibration on data. I have found the following document. "Gettin...
Resolved! LIS3MDL Power Down Mode Issue
Hi,We are using LIS3MDL in our application and current consumption in Power-Down mode is 0.2mA which is quite high but it should be 1uA as per the datasheet.Any suggestion on why I am unable to achieve 1uA level as mentioned in the data sheet?Regards...
SKund.1 by Associate II
  • 6232 Views
  • 13 replies
LIS2DH Raw output data noisy
I am reading the 3-axis data while turning on Inverter and cold cathode tube.The 3-axis data is too noisy. Is LIS2DH affected by external noise?Also, How can i reduce the noise on the raw data? (e.g. Exrta sheelding)
BBQ by Associate II
  • 1313 Views
Problem while programming with Algo builder
Hi,I use Algo Builder to test the sensortile.box, but I can't program the board using the algobuilder software (after I have compiled) in order to test the functionality, even if it seems to be possible to program the microprocessor using directly ...
0693W00000AODlwQAH.png 0693W00000AODmVQAX.png 0693W00000AODmkQAH.png 0693W00000AODmuQAH.png
CDent.1 by Associate II
  • 24172 Views
  • 19 replies
