How to import stm32 PCM data into my computer
I'm trying to convert a PDM data stream from a MEMS microphone into PCM. I think I managed to get a code working and now I want to verify that the acquisition is good. In my test code, I store all the PCM data into "uint16_t pcm_data[30000];"While in...
EEnco.1 by Associate III
  • 3095 Views
IIS3DWBTR Filter LPF2 frecuency response
Hello Community,We have been using the IIS3DWBTR sensor for some time and have observed some odd behavior regarding filters. We recently performed some experimental tests on the LPF2 Filter to corroborate the frequency response curves on page 20 of t...
0693W00000KZwDXQA1.png 0693W00000KZwDDQA1.png 0693W00000KZwEaQAL.png 0693W00000KZwFEQA1.png
MSierraA by Associate II
  • 2274 Views
Resolved! Question about SAI configuration with a MEMS microphone
I want to connect a MEMS microphone to my stm32 using its SAI interface. I found a document called "Interfacing PDM digital microphones using STM32 MCUs and MPUs" which gives some examples about how to do it.My question is about the configuration :Wh...
  • 2668 Views
Resolved! Unable to convert PDM data to PCM data using pdm2pcm
I'm using a stm32wb55RG. I'm trying to get data from a MEMS PDM microphone and convert it into PCM data. I'm using SAI PDM interface and DMA. So far, I think I manage to receive the PDM data (I get some values from the SAI interface) :I don't know if...
  • 3539 Views
「LIS2DU12�?3軸加速度センサー�?�アプリケーションを確�?�?��?��?��?��?�。 �?��?��?気圧センサー�?�連�?��?��?�階段昇�?を確�?�?�る�?��?��?��?�能�?��?�ょ�?��?�?
�?�世話�?��?�り�?��?�。トリニティ株�?会社�?�張�?�申�?��?��?�。弊社�?�ウェアラブルデ�?イス用�?�加速度センサーを購入�?�る予定�?��?�り�?��?��?��?貴社�?�「LIS2DU12�?3軸加速度センサーを�?�定�?��?��??�?��?�?�定�?�る�?�?�。該当センサー�?�アプリケーションを確�?�?��?��?��?��?�。計測�?��??る詳細データを教�?��?�頂�?�る幸�?��?��?�。例�?��?�:歩数�?ランニン...
MZhan.6 by Associate
  • 931 Views
1. Does the MotionDI library output the gravitational acceleration along with linear acceleration as I am getting it in the lin acc. data? 2. How to wipe out the effect of gravitational acceleration in linear acceleration? Sensortile kit is used.
Sensortile kit is used and linear acceleration is fused output from gyroscope and accelerometer,the sensor is kept with z-axis of accelerometer being parallel to gravity (screenshot attached).
MAhm.1 by Associate
  • 1825 Views
