Resolved! Influence of magnetic fields in MEMS accelerometers
Good morning,I would like to know if measurements of MEMS accelerometers/inclinomteres are influenced by near static magnetic fields.The question is generic but regards particularly the model IIS2ICLX.Thanks for the attention.
Guille by Associate II
  • 3995 Views
LIS2DH12 FIFO after interrupt.
Dear community,i have one more problem with my lis2dh12 project.So my sensor run in STREAM-TO-FIFO mode.After init. i can interrupt my sensor und get the right data.After some time my uC go into sleepMode (deinit i2c bus).When i trigger my lis2dh12 a...
TGeld.1 by Associate
  • 1353 Views
SMD footprint recommendation for LIS2DH12
I need to understand what is the right SMD footprint recommendation for LIS2DH12.Recommendations in TN0018 SMD guideline AN , ultra librarian recommended land pattern and footprint actually used in DIL24 adapter significantly differ from each other. ...
MFish.1 by Associate
  • 1925 Views
Lsm6dso : how to get accelerometer data in FIFO
I'm working with lsm6dso for activity monitoring project. I want to record the acc and gyro data in the fifo and trigger an interrupt when the number of samples in fifo are more than the configured watermark. I already achieved to get the gyro data i...
ADvor.2 by Associate II
  • 3541 Views
LIS2DH12 STREAM-TO-FIFO reset
Hello,i have a problem with my lis2dh12 acc sensor.I use the sensor in low power, 8bit with 100Hz and STREAM-TO-FIFO mode.After a interrupt, i read out all 32 FIFO reg and the INT1_SRC reg. These value look good. But when i trigger the interrupt agai...
  • 1090 Views
