Resolved! LSM6DS3TC-R I2C issue
Hi,I am using a XIAO BLE Sense Board that uses an nRF52840 MCU and an LSM6DS3TC-R connected via I2C. The original bootloader from Seeed works fine with their library for the gyro sensor and I am now trying to develop my own with the nRF5 SDK.At the m...
LIS2DS12TR sleep inactivity bit doesn't change correctly
Hi,Because of internal pullups on several st accs I changed it with this acc and, now I have a problem with sleep-state or sleep-state-ia bits in wake_up_src or state or state_dup regisers. This bits after the sleep duration doesn't give a response o...
Zek_De by Senior
  • 959 Views
ISM330DLC - Gyroscope ODR and bandwidth relationship
Hi, I'm currently trying to determine the bandwidth which should be used for different output data rate setting for the gyroscopes on this IMU.The datasheet specifies the exact bandwidth for the accelerometer for different settings as ODR/2, ODR/4 ec...
JStep.3 by Associate
  • 1195 Views
