LPS28DFW and LPS22QS
For my thesis, I need a pressure sensor for air with water vapor and scattered water droplet. The pressure ranges from 100 to 300kPa.abs and the temperature from -30 to 70℃.After searching your website, I find two potential pressure sensors, namely L...
PHONG.1 by Associate
  • 1255 Views
Where to add the training data, .ucf into IMU sensor driver and add detection flow into IMU sensor driver once the gesture is detected?
Dear Sir, After performing IMU MLC training process by UNICO GUI and coming out training data, .ucf, please advise us where to add the training data, .ucf into our ST IMU sensor driver and where to add detection flow into our IMU sensor once the ges...
MSun.4 by Associate
  • 912 Views
lsm6dsl AWT interrupt
helloi use STEVAL-MKI178V2 (adapter board) + STEVAL-MKI109V3 (motherboard) with UNICO-GUI ver9.13.i try "Absolute wrist tilt" example as it described in "AN5040 - Rev 3".The questions are:- in "A_WRIST_TILT_Mask (59h)" register, each bit by itself wo...
ABran.4 by Associate II
  • 1066 Views
PDM MIC with SSC Clock
Is it possible to run any of the ST PDM mic sensors with a spread spectrum clock input? What implication does that have on audio quality? For example, is it possible to run any of the sensors with a clock input of 3.075MHz PDMCLK with 0.5% center spr...
