Resolved! Regarding motion FX library
Hello Everyone,I am using ISM330DLC and able to read X,Y,Z and motion FX library in my application (Gyroscope) to get Eluer angle's and here is my doubt that before giving the senor raw data to the FX library, we supposed to do the gyroscope calibra...
Anil3 by Associate III
  • 1861 Views
MotionFX library and MotionMC
Hi, I'm using MotionFX library v3.0.0, even if i do compass calibration, yaw value is still drifting some times. do I need to use MotionMC library to get better results?
LIS2DW12 latched mode
Hi Experts,I am using lis2dw12 accelerometer connected to esp32s3 and recently have got a situation which is blocking for esp32s3 to read status registers of accelerometer when LIR =1 (latched mode). I put accelerometer on stationary  mode and routin...
farshad by Associate II
  • 4545 Views
  • 10 replies
Resolved! How to read FIFO of LIS2DW12
GreetingsI am trying to read from the FIFO of the LIS2DW12. What confuses me, is that reading through the datasheet, there are only registers which indicate the number of unread samples in the FIFO (FIFO_SAMPLES (2Fh)), and a control register FIFO_CT...
ZAIDS-S23 by Associate III
  • 4302 Views
LSM6DS3 FIFO Status/FTH for Continuous to FIFO
I am trying to configure a LSM6DS3 to capture Tap events in the FIFO similar to how Unico does. i.e. I press "Continuous to FIFO" button (to enable a new capture), then tap the sensor, and the acceleration of the tap event appears on the screen (afte...
SS13 by Associate II
  • 5000 Views
Resolved! Difference between IIS3DWB vibration sensor and ISM330DLC?
Hi,I want to know the difference between IIS3DWB and ISM330DLC.Why we are calling IIS3DWB as vibration sensor while ISM330DLC has accelerometer inside with the same specifications as in IIS3DWB? Which is better in monitoring the vibration in motors?T...
RJain.1 by Associate III
  • 2268 Views
Resolved! LIS2DH12: access LIS2DH12 in historical order?
I want to let the LIS2DH12 FIFO fill and wrap freely and then at a point in time access the history (LIS2DH12 contents) in a particular manner.  I want to first read the newest 15 samples (in any order) and then read the oldest 15 (in any order).  I ...
mchahn by Senior
  • 1658 Views
Regarding Switching On/Off LIS2DH12TR sensor
Hi,We are using LIS2DH12TR accelerometer sensor in our application. Attached is the circuit for the same. We are using a P-channel Mosfet part# BSS84W-7-F to switch the sensor on/off. We are able to switch On the sensor through the Mosfet but we are ...
KLakh by Associate II
  • 1684 Views
