2015-04-20 2:29 AM
I'm trying to achieve a communication between two wifi devices through a SPWFO1SA.11 , and I want to achieve the highest possible bite rate. My questions are then:-Can I use the mentioned SPI port to perform the AT commands?-Can I use the GPIO to transmit data to the SPWF to create a file for instance?Best regards,Hector #spi-error2015-06-30 6:01 AM
Hi, thanks for your answer.
I bought the modules at mouser.com.Can you explain me or give me some tutorial to update the FW?Thanks a lot.2015-06-30 6:25 AM
Download complete package from ST website: http://www.st.com/web/en/catalog/tools/PF260799
You can follow the tutorial inside it, about serial and/or OTA update.2015-07-01 6:10 AM
Than you, I'll try to do this.
