2019-08-03 10:30 PM
HelloI I've read datasheet of STA8090WG, but intead of clarity, many questions arose. First of all, is this chip come with preintalled firmware, or I shoud flash it by myself?
Whether there is a reference circuit for this chip?
Which interface I should use to communicate with device: I see that device have USB, I2C, UART. But there is no information about communicate with device. For example, which I2C address I should you to access to this chip?
Which commands I should use to communicate with it?
2020-04-14 12:51 PM
any answer for this issue
I have a same issue also for STA8090WG . Datasheet and documentation is not good
2020-04-14 12:57 PM
Expect to be doing $1M in business with ST to get access to technical docs and engineering support.
Contact your local sales office to determine if you are a qualified customer for these ICs
Probably want to start with an evaluation board, and get the design documentation for that
https://www.st.com/en/evaluation-tools/evb-t3.html
