2016-07-13 5:56 AM
Is it possible to perform a HTTP DELETE or HTTP PUT through the AT commands (without opening socket etc.). Is it possible using the custom request command AT+S.HTTPREQ? I have found no example of how to use AT+S.HTTPREQ.
Regards,Pontus #http-request-delete-put-at2016-07-18 2:31 AM
there are several howto on this forum about httpreq command. I think it's possible to perform every request you need using that command.regardsjWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
