2014-06-14 9:16 PM
I'm in the process of replicating the bluetooth radio design in on pg. 37 here:http://www.st.com/st-web-ui/static/active/en/resource/technical/document/user_manual/DM00099259.pdf
, and I'm having difficulty locating the AN2051-254 2.4GHz bluetooth chip antenna used in the design.Other than contacting the antenna manufacturer () in Taiwan I think, does anyone have any tips relating to how I can source the chip antenna used in the design or know of a similar antenna that has worked with the dev. kit schematic.Since I have limited access to the kind of equipment I'll need to tune an optimized matching network, I'm trying to minimize the number of variables required to design a functional circuit.Thanks. #bluenrg2014-06-16 7:21 AM
At the following link: you can download the application note ''Low cost PCB antenna for 2.4GHz radio''.
regards, GraziellaWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
