2014-12-09 10:41 PM
I'm trying to set the advertising data and make it advertise, but the client doesn't detect any of the data. Here are the command that I use: HCI_LE_Set_Advertizing_Parameters HCI_LE_Set_Random_Address HCI_LE_Set_Advertizing_Data HCI_LE_Set_Advertize_Enable What am I missing? Thanks2014-12-11 1:47 AM
Hi Dimitar,
Using the commands below, the client device should be able to see the device. Anyway, could you tell me which parameters are used? Regards, GraziellaWe’re moving the ST Community to a new platform to give you a better and more reliable community experience.
