What is different between ST3232 and ST202?
I knew that ST202 is compatible for ST3232. So I changed only ST202 into ST3232 without any circuit changing.But ST3232 doesn't work.​What is different between ST3232 and ST202, other than power supply voltage?​I found the difference in typical appli...
TShim.8 by Associate II
  • 2172 Views
Repeat scanning
Hi everyone,I am developing a simple scanner using the BLUENRG-M0 from ST. I have a custom board wtih an MSP430F5255I just want to make multiple scan to discover other device of interest around.I am following the ACI API from ST and my first scan is ...
GBara.3 by Associate II
  • 829 Views
BlueNRG -2 Sensor-demo code not working.
Hi Team,I am using stm32l475vg MCU and board is B-L475EIOT01.If I create sensor demo project with BlueNRG-1 then it is working properly but If I create same project same configuration with BlueNRG-2 then it is not working.It is stuck in here for Blu...
0693W00000UFOkDQAX.png 0693W00000UFOkNQAX.png 0693W00000UFOkcQAH.png 0693W00000UFOmsQAH.png
