L9637
Hi,I would like to know if L9637 transceiver can be used with LIN protocol.I would also like to know if this transceiver can be used in a system bus where there are many Electronic Control Units (ECUs) and their communication is through of K-line and...
Aarong by Associate
  • 814 Views
TESEO: 3D-Fix, wrong position at low SNR
Dear all.I am working together with a company facing a problem with TESEO-GNSS-Receiver in Japan. In an automotive usecase, with low SNR, the receiver gives us a wrong position, we've seen it off by up to 200 Meters. This alone would not be too bad, ...
VD6283TX ALS not working properly
Hi ,I am working on STM32L0 series controller with VD6283TX ALS on I2C interface.Though code is available for the sensor, my requirement is to write own code that will control the sensor. Sometimes it reads the RAW data from sensor and sometimes it ...
BChav.1 by Associate III
  • 3324 Views
eSim
Hi, I am looking for typical application in the datasheet (for example - ST4SI2M0020TPIFW) and and find nothing. Do you have some typical schema? What does the eSim connect to? What else is needed in the way to the processor? Thanks for examples
RomanD by Associate
  • 947 Views
STUSB4500L Schematics review + questions
Hello all,I am attaching the schematics for a PD sink system we have designed and built. Our aim is to get this sink system to accept both PD and non PD type C power supplies and transfer their power to the 'FRONT_PWR' path on our schematics.Of cours...
NDvas.3 by Associate III
  • 2104 Views
Resolved! Where can I download the BlueNRG stack images?
I have been searching through the ST website to try to find the BlueNRG stack image v2.1c (the bluetooth 5.2 compliant version). If I search "stage image" under the "Tools and Software" section, I get results for other versions (such as STSW-BNRG-V63...
BPaik by Senior
  • 3541 Views
