CR95HF external antenna design
Hi all,does someone know where can I find a reference design for an external antenna? I would like to connect it via the u.fl connector to the CR95HF. I have found a tool ST25R Antenna Matching Tool. Can I use the same tool for CR95HF? If so what sho...
msmiha by Associate
  • 929 Views
BLUENRG-LP deepsleep mode + ble
Hello st community,I'm trying to use the BlueNRG-355 in deepstop mode with timer, to wake it up with an I/O. I used function from Power Save Modes project from the Navigator with Bluetooth function. while(1){ ModulesTick(); APP_Tick(); HAL_PWR_MNG...
akkkkkk by Associate
  • 1557 Views
Resolved! X-CUBE-BLE1 or X-CUBE-BLEMGR
Hi all,I've a project on STM32CUBEMX and STM32CUBEIDE and I'm going to use the STEVAL-STLKT01V1(https://www.st.com/en/evaluation-tools/steval-stlkt01v1.html ) so I'll have to decide what to choose between X-CUBE-BLE1 or X-CUBE-BLEMGR.Does anyone have...
rdl by Associate III
  • 1983 Views
bnrg2a1 rf-flasher
I have a BNRG2A1. I used  RF-Flasher utility to load a first firmware on the board. After that, I tried to load to the board a second firmware, but I'm not able to do it anymore. the jumper in J15 is on, so the board should be in bootload. Any sugges...
IVent.1 by Senior
  • 1136 Views
X-CUBE-NFC6, how to view UID Live Terminal?
Hello,I am using a  NUCLEO_L476RG and a X‑NUCLEO‑NFC06A1 for ST25R3916 expansion board. When I run the demo of X-CUBE-NFC-6 in stm32cubeide, I am getting visual active feedback from 13.56 MHz tags, but I do not know where to see the Live UID Terminal...
Noot by Associate
  • 981 Views
