S2_LP UHF module PROTOCOL
Hello community users!There is a question that needs to be asked. Any help would be greatly appreciated! We want to know Can S2_LP UHF module receive the differential correction data generated by our own gnss base station? So we'd like to know the su...
Eric-Liu by Associate
  • 796 Views
stsafe-A110 key generation speed
Hello,We're using mbedtls on stm32, and key generation for tls is slow. So, we've tried using a stsafe a110 for the key generation, and while looking on the i2c bus, we've seen that key generation from stsafe is about 900 ms.Is this intended ? is the...
Jerome1 by Associate
  • 1719 Views
Get Full HD via USB High Speed
Hello.I want to get video data from USB High Speed and send to DSI interface. Video Resolution is 1920x1080, 30 fps, colors depth 8 bits. Is it possible to make this decision? If yes, what MCU you recommend me?
Fiord by Associate
  • 1519 Views
ST4SI2M0020TPIFW Truphone
The ST4SIM-200M model chip already has the Truphone operator pre-installed as I found out. So is the chip blocked for only one operator? Is it possible to upload an eSIM to the chip using the Android interface and the provided QR code from operators ...
Luk1 by Associate
  • 1178 Views
How to wire BlueNRG-M2SA for UART communication
What pins should we use if we would like to interface with the BlueNRG-M2SA module via UART. We currently use a UART interface on an older competing Bluetooth module and would like stay with that communication interface instead of SPI which is used o...
SPhil.3 by Associate II
  • 2449 Views
Interfacing STEVAL-IOD003V1 with arduino uno
Hey, I am a new user at this forum sorry for any lack in communication.I have an IO-Link sensor and would like to interface it with Arduino uno and after research found STEVAL-IOD003V1 IO-Link transceiver and found it helpful for my application I wan...
Devanshu by Associate II
  • 2981 Views
