spirit features
Posted on March 13, 2014 at 16:21I know ''normal modes'' should be used when receiving WMBus or basic packet format frames, in fact the application also read FIFO to get only payload, no preamble and no sync are included.  ''direct through FIFO'' p...
maengtae by Associate
  • 1371 Views
SPWF01SA.11 OTA firmware update error.
Posted on March 17, 2015 at 20:38I am attempting to update my SPWF01SA.11 firmware using the AT+S.FWUPDATE command. I have an apache server running on my PC that contains the Rel. 3.3 .ota file. The exact .ota file is SPWF01S-141106-0950875-RELEASE-...
[Solved] SPWF01SA switch from Data to Command mode
Posted on March 09, 2015 at 06:13Hello!I'm configure my SPWF01SA.11 module as udp server:>>>at+s.sockd=8899,u OKThen send from PC some data. Module response me+WIND:61:Incoming Socket Client:192.168.0.100   +WIND:60:Now in Data Mode <sended data>How...
hamper by Associate II
  • 1411 Views
Can't get LE ADV Report event (3E 02)
Posted on February 18, 2015 at 13:55Hi,I' m implementing a driver right on top of the HCI interface.I can get most of the events I need except the ''LE Advertising report'' event.I know the BlueNRG chipset receives a Advertising message from over th...
philippe1 by Associate II
  • 1416 Views
Console quantity
Posted on February 25, 2015 at 18:01Reading some discussions I noticed that some versions allow 3 serial consoles and some my just 1 console.Is it right? There is anyway to ''create'' a second console to uart com?Older versions of UM1695 have the sa...
SPWF01SA IBSS
Posted on February 25, 2015 at 12:08Hi, I'm using STEVAL-IDW001V1 and STEVAL-PCC018V1 boards.I set up wifi into IBSS mode named ''ADHOC'' but I cannot detect it from the telephone or browser.I've the impression I'm not creating the ADHOC network. Wh...
pietro by Associate
  • 2249 Views
