Resolved! Question about ST eSIM solutions
Hello,I was researching ST eSIM offerings, and what I found out is that SIM provisioning goes through partner 1Global. My primary use case is to be able to provision the eSIM with multiple profiles without using 3rd party.Can you please tell me are t...
STSW-IOL4LSV1 productive usage
Dear all, Im currently using STSW-IOL4LSV1 package for evaluation.My Company has no IO-Link venodor ID, based on IO-Link regulations we are allowed to develop devices for ourself even without it but we dont want to use our old Stack anymore. I cannot...
Balun Open Tx pin
Hello,I'm using BALF-SPI2-02D3 with the S2-LP chip at 433MHz.However, my application is only for reception, and no RF transmission. What should I do with the Tx pin on the Balun? Open, Resistor to GND or Capacitor to GND?I also need the same answer f...
Resolved! STPM3x Evaluation Board Shorting
 I am working with the STPM34/STPM33 chip and using the STPM34 evaluation board. I have noticed in my own hardware and the eval boards that when you attach power to measure voltage it shorts something and blows up. Is this a known issue? Is there a k...
