ST60 60Ghz transceiver development board
I saw the B2279 ST60A2G0 Circular Patch antenna RF board listed on the attachment (ST60A2 product development kit list). How can i find more info about that ST60A2 development board? I want to know more about the circular antenna used in RF board & s...
EcA1 by Associate
  • 2277 Views
ST60 transceiver
Hello everyone,I am currently working with the SKA2DHV module based on the ST60 and I’m facing some difficulties in finding detailed information about it, especially regarding the interface specifications. The documentation mentions the need for an S...
BlueNRG-M2SA  and error code 0x28
Hi everyone,I am developping an application on the BlueNRG-M2SA module (BLE 4.2) supporting Multiple connections.In my case, the BLE device is configured as PERIPHERAL and is able to serve two connections from two different Android devices simultaneo...
ilias by Associate II
  • 1085 Views
How to activate an e-SIM on SIM7600
Hi, I am using a SIM7600 and a SIM card to get cellular connectivity. Now I would want to use an e-SIM instead of the SIM card holder. However I cant find information regarding if ST Electronics e-SIMs could use any cellular network provider or if it...
MCrespo by Associate
  • 8517 Views
What is the ESD Rating of STKNX IC?
We have used the STKNX IC in our Product as transceiver. In the ESD Test, the IC failed to sustain. The layout and components of the peripheral circuit is as per datasheet and reference from EVALSTKNX Board. Please guide urgently.
SV.11 by Associate II
  • 4247 Views
Resolved! ST4SIM-200M eSIM profile configuration
Hi everyone, In my company, we are currently working on the IOT solution that implements ST4SIM-200M module on our PCB. To shorten things up, we are using SIMCOM modem with the psychical SIM card and it's working ok as we expected. Our next step was ...
S2-LP automatic ACK
I’m testing S2-LP sub-GHz transceivers in stack packet mode. I’m encountering an issue where the sequence number in ACK packets sent by the receiver doesn’t seem to be populated correctly. If I’m not mistaken, when automatic acknowledgment is request...
pelgrimo by Associate II
  • 763 Views
