Acknowledgement function
Hi. I’m using ST examples SDK_STackLLP_A, SDK_STackLLP_B. I want to configure the net with two transmitters and one receiver. This is my net:While I use one transmitter and one receiver my net works properly. Transmitter sends the message and then ge...
EEmel by Associate
  • 903 Views
Drawing STM32F746 with Ethernet LAN8742A fail
Hi all,please help me this problem.Now, I drawing STM32F746ZG with Ethernet LAN8742A like picture below.I don't know why when I testing it not work.I made sure soldering ok. And code I already test on NUCLEO-746G kit. it work well.Could you give advi...
TPham.17 by Associate
  • 936 Views
Not sure this is the best place since there are only two posts since 2017. But here goes. Is there a way to bypass the stepper driver ICs to use an external stepper motor driver?
I see in the user manual there are 4 user pins, User1-4, somewhere in the J23 40pin header. Is it possible to reroute the direction and step signals, pins Pins40&47 of the F401, that would normally go to one or two of the L6474 stepper driver to two ...
TJM by Senior II
  • 1083 Views
