BlueNRG-M0A
We are interns, and as part of our internship project, we tried to create a replica of the STEVAL-FCU1V1 board. We are currently at the firmware uploading stage. After uploading the STSW-DRONE001 firmware, we noticed during debugging that our board i...
SPIRIT1 TPMS
I am working on a Tire Pressure Monitoring System (TPMS) application. This is not a device that goes inside of a tire. This will be a device that talks to the TPMS devices inside the tire. I found the SPIRIT1 as a good choice for sub 1 Ghz wireless r...
ARP by Associate II
  • 1135 Views
Resolved! STUSB4710A not found
Hi everyone, I am new for STUSB4710A. I connect STUSB4710a STEVAL_ISC004v1 evaluation board to my laptop, through a min b usb cable. when I run the graphic interface en.stsw-stusb001, there is one error: usb error: no target found. please connect fir...
Dwang.3 by Associate II
  • 5067 Views
STPM33/34 RMS Current Calculation Error
Hi everyone, I met a problem when I measured the current rms value with stpm33 ic.I'm using this IC with resistive loads and other load profiles with low crest factor. But I met a case with a high crest factor load like as SMPS type loads. I collecte...
bsahan by Associate II
  • 5813 Views
  • 11 replies
BlueNRG-mesh sniffer
Hi,How can I capture packets in my mesh on BlueNRG-2 module? How can I know if a module has passed any package to another module? I see packets directed to a specific module, but I don't see being an intermediary in the network.Regards Adam
Adam0 by Associate
  • 954 Views
STPM34 Init Issue
Hi. I am using two STPM34 on my board, they are separated, UART, SCS, SYN, all of them. I got init issue happens at start-up. I can't detect it. I've applied this Getting started with the STPM3x document procedures and got driver code that provided b...
yucelc by Associate
  • 713 Views
