Resolved! Trace code for M41T81SM6F
Trace code for M41T81SM6FOn label trace code mentioned is CZ441 but on part it is MZ441Our IQC team wish to know why it is different.
Hi, I would like to explore the possibility of using the sub1GHz product solution from ST, particularly, the part number S2-LPTX.Here are the requirements1. We need One Receiver and 4 Transmitter (as shown in the image) which are operating at 433MHz ...
Hello! I try calibrate STPM34 device, but have some troubles.I created some xmls file with Reference Manual and AN4470 and compare results by STPM3x_Evaluation_Software and it different. 1) RM use default Vref value as 1.18, but App use 1.22) Calcula...
Hello,I recently purchased the STEVAL-IDP004V2 board, and I'm encountering an issue when connecting it with the GUI V2 ST and the TE Concept IO-Link application. The same error repeatedly appears: "master application 6148 Appears and Disappears."Coul...
Hello,I have questions about the STUSB1600:1. Mouser marks the device as "obsolete". What is the EOL of the STUSB1600 and what alternative is recommended (STUSB1700?)?2. The STUSB1600 is connected to the MP1 via I2C. I need to program the NVM "in sys...
Hi,I'm trying to configure DIO1 and DIO0 as outputs in my custom board, but I can't get them to work. I'm using this basic code to test:SysCtrl_PeripheralClockCmd(CLOCK_PERIPH_GPIO, ENABLE); GPIO_InitOutputPinx(GPIO_Pin_6); GPIO_SetBits(GPIO_Pin_6); ...
I am looking for ST60A3 (B2309+B2310 or B1214+B2310 etc...)discovery kit in Taiwan.I try to find it on the official STMicroelectronics store, but I could not find any related information.How to buy ST60A3 discovery kit in Taiwan?
Hello, I'm using STEVAL-IDB011V2. From the BlueNRG-LP Navigator, I can load the examples on the board. But when I'm using the Keil, it says "SWD/JTAG Communication Failure".On the options for target in the tab "Device" the device is BlueNRG-355, and ...
Dear Support,Good day.What is the meaning of the suffix that indicated on the label itself for the second line part no.?Is it because of the COO that makes the suffix different? Or it’s just the internal code for STMIC?
Hello ST Team and Community,We are in the process of designing a new product line for my company using ST's ISM transceiver S2-LP along with BALNF-SPI2-01D3 broad band BALUN. This BALUN has 50 Ohm impedance matched with S2-LP transceiver for 860-930 ...
