Hi Sir/Madam,In STblemesh app after configuring the node we can observe node number also element number. what elementNumber means in the app. Also in the firmware part calculated element number following way. Can you explain why we calculated this w...
Hi Sir/Madam,I want to operate 3 LED's individually from one STEVAL-IDB008V2(STSW-BNRG-Mesh) using STBLE_MESH app. Each led should have on/off/dim functionality. Where to change the code(both firmware and app). Can you give idea to solve this?Regards...
Hello,in our application, we are using STEVAL-STLKT01V1 boards.Although we are using onboard USB with ST VCOM driver implementation, I'm wondering if we need to get some permissions for using the existing product id. Other manufacturers provide the c...
plzzzz reply the answer how can i update the firmware of BLE mesh
Hello! I am very new at this and I don't understand a lot, so please be patient.I have an STM32WB55 to which I need to connect an SD module to store data from some sensors in SPI mode. I basically followed some tutorials and got to the conclusion tha...
Hi all,I'm trying to use the X-NUCLEO-PLM01A1 expansion board with the NUCLEO-F401RE board. I've been following the instructions to bring it up, and one of the instructions was to install the STSW-PLM2GUI to be able to interface the boards with the E...
Hello, I would like to ask you for help with programming and debugging the BlueNRG-M2SA module.I am just not able to get started and successfully connect to the module using ST-Link v2 over SWD. Neither using USB-UART chip (PL2303SA) to communicate w...
can we generate basic code for blue nrg 232 using blue nrg gui with out hardware module, any evaluation board.
I was following a video tutorial for F(S)MC setup for an 8080 LCD interface. I have an Elegoo ILI9341 shield. When I ran the code, my display was just a flashing white background no matter what functions I tried to call.All of the tutorial functions ...
