BlueNrg2M2sp Invalid HCI Command
Hi i am using Bluenrg 2 m2sp as network processor mode , Here when i sent aci_gatt_update_char_value_ext command , some times i getting getting invalid command response . may know the reason , if i get invalid response , shall i retry same com...
MCV.1 by Associate II
  • 1324 Views
Object Transfer Service with X-NUCLEO-BNRG2A1
I use a X-NUCLEO-BNRG2A1 with a NUCLEO-L476RG .Is it possible to use the Object Transfer Service? In the documentation it is written that the L2CAP LE Credit Based Flow Control Mode shall be supported. My goal is to transfer a driver
a28j by Associate II
  • 864 Views
Hi. Can anyone tell me how to BlueNRG-X_Flasher_GUI.exe to program the target chip? Command Line Download Fireware......
Dear ALL,​I can use BlueNRG-X_Flasher_GUI.exe to program the target chip,please see attached picture 1 But I want to use BlueNRG-X_Flasher_Launcher.exe to download, but I can’t do it. Hereis my attempt to follow the Commands.Below is the command I tr...
TYang.5 by Associate
  • 687 Views
Library for S2-LP and SPIRIT1 with contiki
Dear All;  I would like to know about X-CUBE-SUBG1 and X-CUBE-SUBG2. There are not work with sensor node library. It has example below- Border_Rounter- Serial_Sniffer- UDP_Client- UDP_ServerCould you please advice me to mesh library with contiki?Than...
Gz by Senior
  • 2240 Views
Configuration of STEVAL-IDP004V1
Hi there,     Recently i bought the STEVAL-IDP004V1 4Port IO-Link Evaluation Board.I am Facing the Issues while Connecting the TE Concept Control Tool and It Showing port is Not Programmed.i am unable to Connect the Sensor.is it possible to connect
Kvenk.11 by Associate
  • 728 Views
