BlueNRG-LP support on Zephyr
A cursory search of the internet shows the Zephyr Community decided not to port the BlueNRG-LP for use with the Zephyr Framework/RTOS.  The reason they gave (in 2023) was: "not planned".  That seemed a bit vague to me.  Though this is likely a questi...
JW by Associate III
  • 1507 Views
Resolved! Inquiry Regarding USB PD Controller Solution to use in simultaneously Charging and Data transfer on USB Upstream port.
Hello,Our product is currently in the testing phase, and we are using the USB2534 hub IC for both data transfer and device charging on downstream port.In our setup, we are using USB 2.0 with a Type-C connector. A pen drive or mobile phone is connecte...
Resolved! ST67W61 How to use it?
如何在 STM32F1/F4 或其他制造商的 MCU 上使用 ST67W61?是否有完整的开发过程?基于 MDK Translated to English by Google: How to use ST67W61 on STM32F1/F4 or other manufacturers' MCUs? Is there a complete development process? Based on MDK.
zsl by Associate
  • 2094 Views
Resolved! ST67W611M1 Module Firmware Update
Dear all, ST67W611M1 is a wonderful module that STM could fulfil the gap for wireless connectivity compared to ESP32, while performing design for the prototype board, I found that the WIKI page did not mention any future update capability and require...
jowyccs by Associate
  • 1358 Views
Resolved! how can I get ST60 module for demo test in China
I want to get a pair of ST60 module for demo test,requirement:1, ST60 for Near Field Communication2,one RJ45 to  another RJ45 transparent transmission;3,module has RJ45 connector\Power connector\buildin antenna;4, support 100Mbps and above;5, Sold in...
LouisL by Associate
  • 1153 Views
Resolved! ST67W611M1 "Reserved" Pins?
Split from this already-solved thread. Hi there,I am also having questions about that module, especially when it comes to the symbol difference between the one found in the X-NUCLEO-67W61M1 product page here:https://www.st.com/resource/en/schematic_...
Taul by Associate II
  • 1137 Views
