2025-06-29
3:56 AM
- last edited on
2025-07-08
7:21 AM
by
Maxime_MARCHETT
Split from this already-solved thread.
Hi there,
I am also having questions about that module, especially when it comes to the symbol difference between the one found in the X-NUCLEO-67W61M1 product page here:
https://www.st.com/resource/en/schematic_pack/mb2230-antenna-a04-schematic.pdf
And the one in the datasheet:
https://www.st.com/resource/en/datasheet/st67w611m1.pdf
Shall we understand the RESERVED pins in the datasheet will eventually be designated as GPIOs (USB, JTAG, UART...)? Or since the dev board schematic files are older than the datasheet, are the peripheral features of the ST67W611M1 being reducted for future releases?
Also as the author of the thread mentioned, what should be done with the RESERVED pins ? Should they be left NC or tied to GND?
Thanks for your support
2025-08-12 6:25 AM
Hi Taul,
The module's pinout is the one described in the datasheet. RESERVED pins are unused and must be left NC.
You can find information on how to connect/route the other pins in this wiki page (search for "Implementation details").
Regards.
2025-07-20 11:45 PM
Anyone?
2025-08-12 6:25 AM
Hi Taul,
Regards.
