2025-04-22 12:28 AM - last edited on 2025-10-21 6:12 AM by Amel NASRI
Hello, I have a problem when I try to run the SPD code under STM32cube IDE, I have this under the serial monitor which remains stuck like this:
SPD ULD SW Kit version 1.0.0
Module type = VL53L8CX
Module ID : 0000000000000000_VL53L8CBV0GC/1$2
FW Version : 1.7.0.0
ULD Driver VL53LMZ_2.0.10
SPD Initialize SPD
2025-10-22 12:12 AM
can you confirm the commands are working? You can try the "help". (the command manager is described in the User Guide, slide 15)
Are you using the P-NUCLEO-53L8A1 boards ?
Thanks,
