Imaging (sensors)
Resolved! VD55G1 Differential Mode
Hi there, I'm trying to figure out how to configure VD55G1 monochrome sensor to differential mode (e.g. disruptive mode, event mode) as branded in user manual. However, after going through https://github.com/STMicroelectronics/stm32-mw-camera, I have...
Resolved! Drivers for VD56G3 Camera Sensor with STM32N6
Related posts* https://community.st.com/t5/imaging-sensors/integration-support-for-vd56g3-camera-sensor-with-stm32n6/m-p/822221#M5767* https://community.st.com/t5/imaging-sensors/drivers-for-st-brightsense-image-sensors-for-stm32n6-series-%CE%BCcs/td...
Resolved! VL53L0X mechanical sizing information
We are developing sensing device with using VL53L0X,  we will use optical lens on top of  VL53L0X  for special sensing purpose then in order to optimize lens design with effecive sensing, we would like to know dimension of both sensor and emitting ch...
Hide1 by Associate II
  • 1655 Views
Using VL53l0x with DMA
I have an application that needs to use several VL53l0x ToF sensors. The measurements need to be fairly responsive to a slow moving object approaching the sensor; so something like taking readings at 10Hz would be reasonable.  Having tried a quick pr...
MikeB100 by Associate II
  • 520 Views
VB1940 Pinout
Hi ST Support.I am currently working with a camera module using VB1940. I could not find a detailed pinout or pin definition in the official documentation. I would greatly appreciate it if someone could help me with that.Thank you very much for your ...
Atoskdke by Associate
  • 638 Views
Confusion on the VL53L1-SATEL registers
Hello, I am currently trying to write code for the I2C communication with the VL53L1-SATEL board. I was trying to confirm that the I2C was working by reading some registers mentioned in the VL53L1 Datasheet, those being 0xC0, 0xC1, 0xC2, 0x51, and 0x...
Carson by Associate III
  • 611 Views
