Imaging (sensors)
Resolved! VL53L1X operation sequence
VL53L1X has VCSELs and 16x16 SPADsWhat I am curious about is the order of operation when reading 16x*16 SPADs one by one.1. VCSEL on2. Read SPAD[0,0] value3. VSCEL off4. VSCEL on5. Read SPAD[1,0]6. VSCEL offwhether or not1. VSCEL on2. Read SPAD[0,0]3...
LYoun.3 by Associate
  • 1157 Views
VL53L1X FOV not operating as per specification
Hi, We have been testing the VL53L1X for a while. The primary intend is to measure the occupation a container (30cmx30cmx80cm) filled by small objects (10cmx10cm). We would like to limit the number of sensors to have a low energy consumption (system ...
ALaga.1 by Associate
  • 1357 Views
Resolved! VL53L0X linearity observation
We are using VL53L0x for measuring piston position inside syringe.We consider piston position at bottom of syringe as reference position.As we move piston to top, the difference between actual and measured reading start increasing.At bottom differen...
YGude.1 by Associate II
  • 1400 Views
Resolved! VL6180X unstable range results
Hi,Readings from my VL6180X sensor are very unstable. They vary about +-8 mm from measure to measure.I tried with Nucleo board and official api, and also with Arduino board and Sparkfun code. 2,8V power supply is from linear regulator, measured objec...
