2025-06-19 12:02 AM - edited 2025-06-19 12:22 AM
I previously successfully trained an st_yolo model for the stm32h7 board using VSCode.
I now got the N6 disco board and cloned the new github page for modelzoo.
After running the stm32ai_mai.py program and having pointed the .yaml file to the correct training path, I get the following error: ValueError: Could not find any .tfs labels files in directory
My dataset is yolo formatted.
I did not get this error previously and am a bit confused by it. Am I in the right road at least and what should I do next?
thanks
2025-06-19 12:37 AM
Hello @dogg,
You can use this script to convert your yolo data to tfs files:
Then in your yaml, use the path to these data for the training, validation etc.
I didn't know it was required to use tfs and it is not written anywhere, I am gathering information, I'll let you know.
Have a good day,
Julian
2025-06-19 12:37 AM
Hello @dogg,
Have a good day,
Julian
2025-06-19 2:09 AM - edited 2025-06-20 12:56 AM
Ok thanks for that. I have trained a mock model to test and now I am trying to load the model onto the N6 but I get this error instead:
File "c:\Users\dogg\Desktop\zooooo\stm32ai-modelzoo-services\common\stm32ai_local\board_config.py", line 208, in __init__
raise STMAICFileError(f'"{project_path}" is not a regular file')
common.stm32ai_local.utils.STMAICFileError: E300: "../application_code/image_classification/STM32N6/stmaic_STM32N6570-DK.conf" is not a regular file
The deployment structure was originally for the H7 board so I had to change it to:
