Wakeup signal
ssk
Associate II
Posted on May 18, 2015 at 11:05
I am trying to configure a wakeup signal WKPU6 as below.
WKUP.WISR.B.EIF = 0x02000000; //Clear interrupt flag
WKUP.WIREER.B.IREE = 0x02000000; //Disable rising edge
WKUP.WIFEER.B.IFEE = 0x02000000; //Enable falling edge
WKUP.IRER.B.EIRE = 0x00000000; //Enable interrupt
WKUP.WRER.B.WRE = 0x02000000; //Enable system wakeup
WKUP.WIFER.B.IFE = 0x02000000;
But when above code is executed, after the first statement, the code looses the track and never returns. What is the reason? I have tried to configure the bits from another end as well. Can you please clarify the behavior? Any test app for wakeup up signal?
Thanks in advance for all your help.
Mike.
#wakeup
2 REPLIES 2
ssk
Associate II
Posted on May 19, 2015 at 12:51
I am attaching my test application herewith. Please respond.
Your earliest help will be highly appreciated. Thanks.
Mike.
________________
Attachments :
Test_Wakeup.zip : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I0R4&d=%2Fa%2F0X0000000bZ0%2FOiTXYSeYQ165b52WzMrHzeIoSBx37TPnVxplXu6twwQ&asPdf=false
Erwan YVIN
Posted on May 20, 2015 at 17:58
Hello Mike ,
You have forgotten to configure the WKPU PCTL it should be enabled in STOP0 Mode
halSPCSetPeripheralClockMode(69,
SPC5_ME_PCTL_RUN(2) | SPC5_ME_PCTL_LP(3));
Best Regards Erwan
