Automotive MCUs
SPC5Studio configuration
Posted on August 25, 2015 at 08:27Hello,I am using SPC5Studio for SPC560D MCU. 1. How can I access CTU configuration from SPC5Studio?2. How can I configure ADC module for using CTU, one shot conversion vs scan, priorities for EOC etc?3. Any user gui...
ssk by Associate II
  • 1262 Views
SPC560 - eMIOS
Posted on August 20, 2015 at 18:04Hello,I am using eMIOS module for SPC560D40L3 MCU for generating PWM. I am using default configuration for the SPCStudio project with no change to FMPLL0 and Clocks settings. My target uses 8MHz external XTAL. With ...
ssk by Associate II
  • 1699 Views
SPC560 - SWT
Posted on August 12, 2015 at 15:03Hello,I am using software watchdog timer (SWT) for the SPC560D40 MCU. What is the 'out of reset' situation for the SWT?Best Regards,Mike. #swt
ssk by Associate II
  • 2019 Views
Problem with Lin Enable filters
Posted on August 12, 2015 at 11:01Hi I Have 2 problems with Lin : 1.When i Recive a data from LIN I have  No interrupt  2.When i want to set a filter in LIN the programm not work at this point in the attachment code :LINFLEX_1.IFMR.B.IFM=1; LINFLEX...
Licence Problem for SPC56_DRV_LIN2.1-0.9.5 Lin Driver
Posted on August 04, 2015 at 17:45Hi I Download this software for using Lin Driver on SPCStudio But When you want to setup this software , the software need a serial number but i send request to apg tools but have no response for my request. i wan...
Bug On SPC560B50L5 UART Mode in SPC Studio
Posted on August 04, 2015 at 17:40Hi I Want to Use LINFELX2 in uart mode in SPC560B50L5 but in HAL Driver Component Have 2 LINFLEX (LINFLEX0 and LINFLEX1) there is not exist LINFLEX2 OR 3 !!!! Are Those driver's not supported or i can not use this ...
SPC560P TSENS corresponding to the voltage
Posted on December 04, 2014 at 04:37Hi, Anybody can give me the table about the SPC560P sampling temperature corresponding to voltage? Best regards Liu Wei #internal-temperature-sensor
How use ICU driver?
Posted on July 07, 2015 at 20:22 Hello, I have to simulate the behavior of this function Arduino on Chibios for the management of my sensor. duration = pulseIn(ECHO_PIN,HIGH); I use ICU driver to detect the rising and falling ...
gl2 by Associate III
  • 4343 Views
SPC56EL60L5CBF ECC Error
Posted on July 10, 2015 at 11:24Hi, Recently we received few returns from customer with ECU entering Error Mode. The only information we have for now is values of registers in time of exeption: 00000020 - ESR        - VLEMI (VLE Mode Instruction) 00...
dariusz by Associate II
  • 2447 Views
