Automotive MCUs
Is there sample application available for SPC570S-DISP?
Posted on November 29, 2017 at 02:34Hi,We have the SPC570S-DISP board which has the SPC570S50E1 MCU. The SPC5Studio Import application Wizard only has SPC570S50L1DISP for the SPC57 S-Line.After import application such as SPC570Sxx_RLA SERIAL Test Ap...
Job Shen by Associate III
  • 3990 Views
Resolved! Timer initialization prompts build error SPC560 test program
Hello,I have built LED blinky test program in SPC560B-DIS eval, I am setting and clearing LEDs in eval bord. I have introduced delay "osalThreadDelayMilliseconds(500);" between set and clear.I have used below code for my application, but it throws bu...
AK V by Associate II
  • 6471 Views
24 Hours coding 2017 ''ST Amazing Race Car''
Posted on February 28, 2017 at 10:36 Title Document: 24 Hours coding 2017 ''ST Amazing Race Car''The annual event took place on 21 and 22 January at the CCI of Le Mans in Sarthe , France. ST Le Mans proposed this year the simulation of a car race. G...
Resolved! SPC560B50L3, Cannot use eMIOS0 ch1-ch7 as PWM outputs?
Hi ST experts,I started with SPC560B50L3 and I am using SPC5Studio 5.8. I have problem with eMIOS0 configuration (ch1-ch7) as PWM outputs.. I use PinMap editor and i configured the pins as eMIOS0 output (eMIOS0 ch1-ch7, eMIOS0 ch9-ch13 and eMIOS0 ch2...
VOtev by Associate
  • 1585 Views
Resolved! How to use EEPROM of SPC560Pxx?
I have data which i need to store in eeprom,but i am facing following issue:The data once written to one block of flash, not able to overwrite the dataThe other blocks not able to use during run time
CRC calculation for Hex file
Posted on March 20, 2017 at 07:38Hi All,I am planning to have CRC calculation for my Hex file generated and i want to keep that CRC at the end memory location of hex file generated ,Is there any option in SPCstudio to enbale CRC so that when IDE is ...
SPC56xx_DRV_FLS_LC_MM-0.9.5.2 Drivers
Posted on February 16, 2016 at 23:36Hello, I downloaded the SPC56xx_DRV_FLS_LC_MM-0.9.5.2 Drivers. To install it I sent a SN request to apgtools-license@st.com. For a week I have not received any response. Should I wait for Serial Number or this is ...
aknyaz by Associate
  • 1363 Views
