Automotive MCUs
Resolved! how to set standby mode in spc560b disc EVK.
Hello,I am not able to activate the module entry in Clock Component RLA. Can you please guide me how to do the configuration for sending the uc in standby mode.
rpoon by Associate II
  • 3445 Views
Resolved! about SPC560Pxx_RLA PIT Test Application for Discovery
I'm experimenting the example SPC560Pxx_RLA PIT Test Application for Discovery.It is simply a 3 led flashing using PIT.Is it possible that the frequency of the example is wrong? It is exactly doubled, instead of 4,2,1 Hzi read 2,1, 0,5 Hz.The quartz...
gp73 by Associate III
  • 1484 Views
How FIFO/filter is working in SPC58xHx(Chorus10M)?
Hello,We are developing demo on Chorus10M using our EB's BSW stack with MCAL from ST.We are confused about how FIFO/filtering/mailbox/buffer is working on this chip.In user manual, we found statement like this: FIFOs will be assigned to ...
QChen.91 by Associate
  • 1172 Views
Where is the SENT demo Driver Source Code?
It was asked by someone else before, but there was no answer, so I ask again.Where is the source code for TN1233?​Below link is a TN1233.​https://www.st.com/content/ccc/resource/technical/document/technical_note/group0/64/dd/1f/5c/49/a5/4b/58/DM00272...
ychih by Associate
  • 1227 Views
how to set SPC560b50l3 to STOP mode?
I am able to set STOP mode in SPC560B50l3 successfully, but still the totalcurrent drawn is 6-7mA.According to datasheet the maximum current consumed in stop mode under 55 °C is 500 uA.Following is the code that i have added to set STOP mode:ME.STOP0...
Rajesh_ by Associate II
  • 1147 Views
flexcanstcomm
Hi DearsFirst (if its important):I want to program for 560b50 and it isn't in platform list. list started with 54. what should I do?Secondly :I configure "enable filters" in flexcan visual configuration from respective component and so generate ...bu...
SChar.8 by Associate II
  • 4353 Views
SPC5studio generated code for spc560C50L3 SPI slave not working
We are facing issue with SPI slave communication for spc560C50L3 controller.The generated code for SPI slave from SPC5studio is not working. We have written a register level code to transmit 1 byte and read 1 byte for SPI slave. The observations for ...
AChan.1 by Associate
  • 3710 Views
