Analog and audio
Forum board changes
marking 2L28I
Posted on November 04, 2013 at 09:54I found an IC,marking 2L28I,manufactured by ST? I want to know it,s order number. #marking-brand
yuegang by Associate
  • 1334 Views
Configuration, set-up or help files for APWorkbench with MEMS
Posted on September 30, 2013 at 15:53Are there any example apc files for the MEMS microphone demonstrator? as indicated in the application note: AP4146, For example basic directional microphone set-up. There seems to be no Help available or very lit...
jmoore by Associate
  • 845 Views
Availability of RHF801
Posted on September 12, 2013 at 18:05JPL has been considering usage of this high speed radiation hardened comparator for a space application.  The product was announced with a target specification.  However, a final specification nor DLA drawing has...
mark2 by Associate
  • 821 Views
PCB Footprint for amplifiers
Posted on July 26, 2013 at 14:45Hi guys,I'm currently working with TSX562IQ2T in DFN8 package.Do you have some kind of recommended footprint for this package? #package-footprint #qfn #dfn
38josa by Associate
  • 1217 Views
Is the TSC1021 capable of measuring negative voltage?D
Posted on July 10, 2013 at 23:19HiI read the datasheet of the TSC1021, but it is not clear if the IC is protected from negative voltage in the Vp/Vn terminals, or cant it measure the current.I need to measure current of negative voltage, and plannin...
avishai by Associate
  • 1313 Views
