Analog and audio
Forum board changes
STDP4020 Firmware Version Detect
Posted on April 03, 2014 at 20:56I am currently working a project to detect the version of STDP4020 firmware. I got all the data bytes of this firmware, can anybody give me some clue how to interpret them, particularly, which part tells the version ...
yao by Associate
  • 1517 Views
Music and notification MP3 player
Posted on February 27, 2014 at 11:32For our industrial application, we implemented a STA013 to play sound files located on a SD card. We have to play background music and sometimes play some notification sound. So we send background music MP3 to STA...
nmagniez by Associate II
  • 1037 Views
TDA7468 volume control
Posted on October 03, 2013 at 20:24Hello! i have a trouble with setting volume level in TDA7468. I use a wiring diagram as datasheet, and send setting to this IC using the C code:void writer(unsigned char adr_IC, unsigned char adr_reg,unsigned char ...
STA350BW 2ch downmix to 1ch (Mono)
Posted on January 20, 2014 at 09:00Hello, in AP-Workbench and Datasheet, i did not found any Switch to generate ''Mono'' from 2-channel Input, with STA350BW Would this be possible using the PEQ? Thank you best regards, Florian Breu #mono-downmix-...
florian2 by Associate
  • 995 Views
TDA7297 ground layout
Posted on January 28, 2013 at 19:36Hello everyone,I can connect the input ground (from audio source) to power supply ground near the filter capacitors?As about pgnd and signal ground I have to connect both to the power supply ground with diferent ca...
TDA7498MV
Posted on August 21, 2013 at 10:19I was going through the data sheet of the above mentiones Amp, can any one explain me the need for  frequency shift in TDA7498MV
ravi_bv by Associate
  • 833 Views
Shall we use differential TDA7575B input as single ended
Posted on July 25, 2013 at 08:48hi form members,   I am using audio amp. (TDA7575B) which has differential input (IN1+,IN1-) but in our case I have single ended input only from my codec, so i planned to connect IN1- pin to ground with a series capac...
bala by Associate
  • 1203 Views
STA350BW Power Supply
Posted on August 06, 2013 at 12:50Hii want to use the STA350BW amplifier but i am not quite sure which power supply i must use.The first page of the Datasheet says:Four power output configurations(a)– 2 channels of ternary PWM (stereo mode)(2 x 50 W...
joern23 by Associate
  • 966 Views
