Analog and audio
Forum board changes
Can't set SPIRIT1 status to lock Tx or Rx
I have been using STEVAL-IKR002V4D (a daughterboard with SPIRIT1 868 Mhz transceiver) to transmit data. I have it hooked with Raspberry Pi. I have followed the driver library example provided in the design kit software. However, I can't initialize th...
RPink.1 by Associate
  • 829 Views
LM2901 : Common mode input voltage range.
What will happen with output when input signal is out of "Common mode input voltage range"?Ex.) Vcc=5V (Vicm= 0 to 3.5V) ---> Input IN-=0V, IN+=4V signals Then, Output go to 5V(saturated)?
RKama.3 by Associate
  • 957 Views
